Hi all, im just inquiring about my Haf X with the Coolermaster silent hybrid pro 850w's fan control that is ment to slot into one of the 5.25" bays. Trouble is that the control panel wont fit. Anyone had this problem and know how to fix it?
Could you provide an image of how it's not fitting, maybe? Also, this may sound silly, but have you tried sliding it in from outside the case and/or from inside the case?
http://puu.sh/2C5rN and http://puu.sh/2C5sP are the best two photos i could get. It says on the manual to install it in the front of a 5.25" bay but there are tho flaps and the supporting bracket in the way. It totally has me stumped (newbie here building my first build lol)
Well I don't think it's gonna fit in with that huge part sticking out. I'm sure it's there for a reason, but it's definitely in the way. http://imgur.com/AgBDpZd
