These are the final parts I've chosen for a budget gaming pc. If you guys know of a better graphics card that is less than $50 more expensive and compatible let me know. Also these are all compatible right?
Dvd drive- http://www.newegg.com/Product/Product.aspx?Item=N82E16827106289
Case-http://www.newegg.com/Product/Product.aspx?Item=N82E16811154094
Monitor-http://www.newegg.com/Product/Product.aspx?Item=N82E16824254094
Motherboard-http://www.newegg.com/Product/Product.aspx?Item=N82E16813131795
Hardrive clip-http://www.newegg.com/Product/Product.aspx?Item=N82E16817997013
Graphics card-http://www.newegg.com/Product/Product.aspx?Item=N82E16814187203
Power supply-http://www.newegg.com/Product/Product.aspx?Item=N82E16817139027
Ram-http://www.newegg.com/Product/Product.aspx?Item=N82E16820231455
Cpu-http://www.newegg.com/Product/Product.aspx?Item=N82E16819103727
Harddrive-my 320 gb slow 5400rm laptop one (will get an ssd in the coming months)
