Need help picking out parts for budget gaming pc
  • Gaming
  • Components
  • Thunder
Last response: in Components
April 23, 2013 8:06:04 PM
Hello. I would like some help picking out parts for a budget pc. My budget is around $300 (excluding OS). I already have a monitor, keyboard,and mouse. (question: can i use my current HDD?)Im planning to play games like war thunder, world of tanks, and garrys mod. Thank you for any help and for reading this post. : )
More about : picking parts budget gaming
April 23, 2013 11:15:23 PM
what components are u going to buy
will u be overclocking and also if u can give ur resolution
and yes u can use your hdd
and games that u have listed r not very demanding and r these the only games u will play
April 24, 2013 2:08:50 PM
i will buy the componets necessary. I will give my resolution as soon as my current pc decides to turn on. I think these are the only games i will play. I will not be overclocking.
My resolution is 1280 x 1024
April 24, 2013 6:43:51 PM
for 1080p hd 7850 or 650 ti boost will be good
8gb(1600Mhz) of ram
processor is something that won't affect gaming as much as the gpu
so there are some choices fx 6300 and if the budget allows i5-3470
April 24, 2013 7:37:38 PM
8gb(1600Mhz) of ram
Um........ These two peices of hardwar are like $300 together. I want suggestions for the other peices too like the mobo, case, etc.(the whole build) im sorry if i confused you in any way.
April 24, 2013 8:45:48 PM
if 300$ is for the complete build u wont get the performance u r looking for
if that is ur complete budget get an apu
AMD A10-5800K - 128$
ASRock FM2A75 - 85$
G.Skill Value Series 8GB - 59$
Antec Basiq Plus 550W - 70$
total=342$
get the cheapest case possible with good air flow
April 25, 2013 5:40:31 AM
ASRock FM2A75 - 85$
total=342$.
Thanks! : )
