Water-Cooling Kit XSPC Raystorm 750 RS240
  • Water Cooling
  • XSPC
  • 6850
  • Raystorm
  • CPUs
  • KIT
  • Components
  • GPUs
Last response: in Components
April 23, 2013 11:01:39 PM
Will the Water-Coolling Kit XSPC Raystorm 750 RS240 be capable of running a full loop with CPU and GPU with the XSPC Rasa GPU Block Used on MSI r6850. Are there any other full loop Kits that would be better than this Kit.
Regards Robert
More about : water cooling kit xspc raystorm 750 rs240
a c 117 à CPUs
April 23, 2013 11:46:56 PM
Nope.
You havent got enough radiator space, and the pump isnt really meant to support more than just a CPU loop.
April 24, 2013 12:02:22 AM
manofchalk said:
Nope.
Is there any other Water cooling Kits that you now of that would do the full loop
