I have a pre-built system from IbuyPower, that I have had for about a year and a half. Twice (that I know of) I have been using the computer and out of the blue I get a "pop" or "zap" (like a bug zapper) noise coming from the tower, immediately followed by the system rebooting itself (these two events were at least 4 months or more apart).
Everything appears to be fine when the system comes back online, but I can only think that something is wrong and this could lead to failures down the road.
I was not doing anything resource intensive when this happened either, so I don't think it is a temperature issue.
I looked at event viewer after it happened last time, and the one that stood out was: Critical event id 41. The description for that event was "The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly."
I have read that it could be capacitors popping, but would the system reboot itself and then be fine if I was popping capacitors?? Should I be worried, is there anything I can do to find out what the noise is?
Specs:
i52500k
gigabyte mobo
8gb ddr3 1600 (do NOT know the brand, could open case and look if I need to)
Corsair TX750 power supply
Thank you!
Specs:
i52500k
gigabyte mobo
Thank you!
