PSU Fan making mechanical noise while in vertical position.
  • Power Supplies
  • How To
  • Fan
  • Motherboards
  • Components
Last response: in Components
April 25, 2013 6:57:14 AM
Hello , today my PSU fan started making strange mechanical noise while in vertical position, but if I put it in horizontal position - that annoying sound stops .
That sound starts after few seconds of turning the computer on .
I checked every fan my PC has and it is definitely the PSU fan .
I tried to tighten the screws that hold the fan, but it didn't help .
My PSU is "CODEGEN 400W" .
My question :
Any thoughts on how to fix it/what should I try to do? I have no spare money to buy a new one (humble student) and I would prefer my PC to be in vertical position.
I can provide photos of my Motherboard/PSU and I can upload the sound that PSU makes if needed .
More about : psu fan making mechanical noise vertical position
a b ) Power supply
a c 242 V Motherboard
April 25, 2013 10:26:49 AM
You could replace the fan if you know what you're doing. Can't you find another cheap PSU?
