CPU fan stops 2 times before going full speed
Hello)
I just built my brand new budget rig for work and some gaming. Nothing astonishing, really. Here are some major specs:
-i3 3220 3.3 Ghz
-ASROCK b75 pro3-m
-XFX Core Edition 550W
After turning on the PC, cpu fan stops 2 times before going full speed with intervals of 1-2 seconds in between of breaks.
Do you know the possible source of the problem? Or if its a problem at all?
Thanks for all your help ;)
1 answer Last reply
More about cpu fan stops times full speed
  1. My Intel motherboard also does that, but I'm not worried as the system runs Prime95 torture tests for hours without issues.
Gaming CPUs
