Hi
I'm in a bit of a situation with my Lenovo h520s in upgrading as I wish to upgrade to a bigger graphics card but the case is too small, and the psu wattage is too low, in order to get a new graphics card i would need a new psu with more wattage and in order to get a normal ATX psu i would need to upgrade the case to either a mATX case or an ATX case,
My concern is, I am not sure what type of Motherboard I have? I think it might be a micro ITX but i am not sure, here is the link to my PC: http://www.pcmag.com/article2/0,2817,2410888,00.asp.I ran CPU Z on my PC and it says my mainboard is called "Lenovo Mahobay" I would also like to know if i could fit my motherboard in this chassis: http://www.overclockers.co.uk/showproduct.php?prodid=CA-033-AE&tool=5
Or this one: http://www.overclockers.co.uk/showproduct.php?prodid=CA-029-AE&groupid=2362&catid=2278
Or this one: http://www.overclockers.co.uk/showproduct.php?prodid=CA-302-CM&tool=5 I noticed on this one it supports mini itx, but I need to know if my Motherboard is mini itx or not!, Help me please
And if none of them do fit, what case can i buy thats big enougn for my needs.
Please reply ASAP!!!!!!!!!!!!!!!!!!
Thank you
Thank you
