Which one LED monitor is best gaming monitor???
  • Gaming
  • LED Monitor
  • Graphics
May 3, 2013 1:31:46 AM
Hi, which one LED monitor is best gaming monitor from Asus VE247H and ViewSonic VX2460h-LED Monitor.
my PC spec is:
Intel i5 3570
Intel H77KC motherboard
Cooler Master Extreme 525W
Corsair Vengeance 8GB (8x1) 1600MHz
GTX 660 Non-Ti 2GB
Please guide me!
Thanks. :)
More about : led monitor gaming monitor
a b 4 Gaming
May 3, 2013 5:00:57 AM
About the same.
Asus has DVI and Viewsonic doesn't
Asus is regular power cord, Viewsonic is power brick.
Asus is VESA mountable and Viewsonic isn't
All that said, they should pretty much game the same.
May 6, 2013 10:24:25 PM
Spaniard United said:
About the same.
You mean that both of these LED monitors are equal for gaming?
Which monitor should I buy?? please guide me. thanks :)
May 7, 2013 12:33:27 AM
How about their price?
Just like dadpad88 said above, they should pretty much game the same... :)
a b 4 Gaming
May 7, 2013 1:35:07 PM
The Viewsonic appears to have a smaller footprint than the Asus, so if space is an issue you might go for that. The Viewsonic has a larger bezel than the Asus, so it that's an important feature for you or if you're thinking about going multiple screens, pick the Asus.
The Asus is cheaper and has more of the features that I personally prefer over the Viewsonic, so if I were making the purchase I would choose the Asus.
As far is gaming is concerned, they have the same specs and should perform the same.
May 8, 2013 10:56:37 AM
ok thank you, i understand. :)
May 20, 2013 11:55:45 AM
please also tell me that either Dell LED ST2420L better or Asus VE247H???
Reply me Thanks!
a b 4 Gaming
May 20, 2013 3:30:01 PM
Asus - 2ms response
Dell - 5ms response
Asus > Dell for gaming
