need help finding memory, cpu cooler, power supply, and case for my build
  • Intel
  • CPUs
  • SATA
  • Cooling
  • Build
  • Components
  • Memory
  • Cases
Last response: in Components
May 6, 2013 9:46:06 AM
this is what i have so far:
ASUS P8Z77-V PRO LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
EVGA 02G-P4-2678-KR GeForce GTX 670 FTW 2GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready SLI Support Video Card
Intel Core i5-3570K Ivy Bridge 3.4GHz (3.8GHz Turbo) LGA 1155 77W Quad-Core Desktop Processor Intel HD Graphics 4000 BX80637I53570K
SAMSUNG 840 Pro Series MZ-7PD128BW 2.5" 128GB SATA III MLC Internal Solid State Drive (SSD)
Seagate Barracuda ST1000DM003 1TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
ASUS DRW-24B1ST/BLK/B/AS Black SATA 24X DVD Burner - Bulk - OEM
btw; for the memory 8GB RAM is enough for me, and possibly a corasir vengeance brand? i just don't know which one to pick lol
More about : finding memory cpu cooler power supply case build
May 6, 2013 10:07:51 AM
cooling: http://www.newegg.com/Product/Product.aspx?Item=N82E168... (worth every penny and very quiet with no lack on performance, easy install also) 114.99
memory: http://www.newegg.com/Product/Product.aspx?Item=N82E168... 1866mhz 64.99 or http://www.newegg.com/Product/Product.aspx?Item=N82E168... 1600 mhz 69.99
power supply: http://www.newegg.com/Product/Product.aspx?Item=N82E168... 109.99 (should handle almost any upgrade u want to throw at it in future including sli or xfire. good for future proof) BRONZE CERTIFIED ALSO!!!
case (that will handle plenty of fans for water cooling or air with good airflow to keep all ur components nice and cool and keep them running) http://www.newegg.com/Product/Product.aspx?Item=N82E168... 109.99 or http://www.newegg.com/Product/Product.aspx?Item=N82E168... 119.99 both support liquid cooling if u go that way in future and excellent airflow. u can really choose any case u prefer but if u got with liquid cooling even closed loops like the 110 make sure u have 2 top 120mm spaces for the dual radiator or go with H90 if u go with a case with only 1 top fan. By the way from now on when u post anything similar try to post your budget so i dont go overboard like i probally did here but if u post a budget i will revamp my selection to fit your pricepoint. all selections were based on personal experience from gaming and personal preference in my experience.
May 6, 2013 10:36:53 AM
oh wow thanks for the suggestions! yeah my budget right now is 2,000 dollars but so far I've chosen 1,100 dollars worth of components.
May 15, 2013 4:46:26 PM
no problem man lemme know if u need any more info be glad to help
