EVGA Geforce Gtx 660 TI FTW 3GB or EVGA Geforce Gtx 670 2GB or 2x Superclocked Geforce Gtx 660.... What Do you recommend
I would like to play BF4 and BF3 in MAX and crysis 3 and ARMA 2
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130782
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130817
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130826
Which one will suit my needs and perform the best, I've got Intel i5 3570k, Asrock Z77 Extreme 4, Corsair 16gb and corsair 750w Modular psu?
5 answers Last reply
More about evga geforce gtx 660 ftw 3gb evga geforce gtx 670 2gb superclocked geforce gtx 660 recommend
  1. 2x GTX 660 would be the most powerful solution. But to SLI there is no point in getting overclocked/superclocked cards as SLI will force them to run at reference speed.
    Last time I heard was that they must both run at same speeds not refrence... But I might be wrong...
    2x660 all the way but 670 if your upgrading in future. Note that new Nvidia GPUs are comming this month :)
  3. Yeah I checked and it seems its possible to overclock in SLI as long as you use something like Afterburner to mirror overclocks across all cards. Not sure if it works automatically with 2 identical factory overclocked cards, also each card boosts individually which might cause problems.
Battlefield EVGA Graphics Crysis Geforce Nvidia Gtx Graphics Cards
