Well, I am building my first computer with some new parts and some salvaged parts. Would someone be able to confirm that all my parts are fully compatible? According to my research from the internet they all should be compatible, but since this is my first build I would like confirmation that everything will work out good.
Thanks
Graphics card:
http://www.newegg.com/Product/Product.aspx?Item=14-102-999&SortField=0&SummaryType=0&Pagesize=100&PurchaseMark=&SelectedRating=-1&VideoOnlyMark=False&VendorMark=&IsFeedbackTab=true&Keywords=%28keywords%29&Page=1#scrollFullInfo
Power Supply:
http://www.newegg.com/Product/Product.aspx?Item=17-139-028&SortField=0&SummaryType=0&Pagesize=10&PurchaseMark=&SelectedRating=-1&VideoOnlyMark=False&VendorMark=&IsFeedbackTab=true&Keywords=%28keywords%29&Page=1#scrollFullInfo
Case:
http://www.newegg.com/Product/Product.aspx?Item=11-119-263&SortField=0&SummaryType=0&Pagesize=10&PurchaseMark=&SelectedRating=-1&VideoOnlyMark=False&VendorMark=&IsFeedbackTab=true&Keywords=%28keywords%29#scrollFullInfo
Fan Controller panel:
http://www.nzxt.com/product/detail/77-sentry-2-fan-control.html
Extra case fans:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835553009
OEM motherboard:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c03353629&lc=en&cc=us&dlc=en
OEM CPU:
AMD FX-6120
OEM HDD:
1 TB SATA 7200rpm
OEM OS:
Windows 7 home premium
Thank you for your time!
Thanks
Graphics card:
Power Supply:
Case:
Extra case fans:
OEM motherboard:
OEM CPU:
AMD FX-6120
OEM HDD:
1 TB SATA 7200rpm
OEM OS:
