Hey forumites,
Been thinking for a long time now about taking the risk of water cooling since incidents of them bursting open has dropped down.
My set up as of current is a Mid size tower stuffed with:
Phenom II 6X 1090T
Hyper 212 plus cooler
Gigabyte GA-970A-UD3
4x4 GB Corsair Vengence RAM 9-9-9-24
Gigabyte Radeon HD 7870 Ghz 2GB edition
700W Thermaltake PSU
Kingston Hyper X 3K SSD (240 GB)
Corsair Force 3 SSD 240GB
1TB Western digital for Logical
Currently my average temps with the Hyper 212 + is 32c idle and upwards to about 55c max ( I dont overclock) (oh and I dont have the side of my tower on)
Gaming has been fairly light for a while, but want to get back into it a bit again, dont do too much intensive things beyond gaming, use photoshop but eh.
In either case I am looking for a good self closed liquid cooling system for my CPU, (thought about GPU cooling too but dont know about that yet)
What I am aiming for is something that is quiet, doesnt take up much room since its not a full tower, and reliable, I dont want any leaks. With AMD down in the dumps as far as processors go I wont be upgrading to an AMD anytime soon (perhaps the i5-3570k in the near future for some light over clocking).
I have been looking at both the corsair line and the antec Kuhler 620 and 920.
I know Corsair has some issues with earlier models leaking, but I have not heard anything negative about Kuhler. I am open to other suggestions but would like to pull away from the hugeness that is the Hyper 212 (cant put my case side back on normal, I had to take the plastic out and turn it around so the fan on it didnt hit the hyper 212)
The tested temps that I have seen are usually done with i7's and overclocked extreme style so I cant get an accurate temperature gauge for normal usage or something since a H60 for example gives the same temps that my hyper 212 does without over clocking.
On another note, going the route of water cooling I will be looking for insurance to give me piece of mind in case some leakage does occur. Does anyone have thoughts or suggestions on this, and a reputable place they know of?
Phenom II 6X 1090T
