I'm making this because I would like for you or if anyone who is wanting to overclock there i5-3570k they can look at my results to see and won't have to go thru the trouble of starting off overclocking.
Hello, I saw this on YouTube and thought I might share it. I do NOT recommend doing this, But I just came across it today. I did NOT have to do this to mine though. Mine was already at perfect temps when stocked.
YouTube Link below
http://www.youtube.com/watch?v=XXs0I5kuoX4
Tips:
Disable Intel Turbo Boost when Overclocking.
Enhance Turbo should be disabled as-well.
On Ivy Bridge CPU's do NOT go over 90C/194.00 if you are in the 83C/181.40 then your ok, But I recommend NOT going over 83C/181.40 to be safe. Even if your liquid cooling.
My i5-3570k clock-speeds/info below.
Running at 4.4GHz
CPU Core Voltage:1.2350
Everything else is pretty much at "Auto" I only messed with the voltage.
Temps below
Surfing Web-39C or 102.20
OCCT Stress Test for 4 hours---Core #0: 76C/168.80
Core #1: 83C/181.40
Core #2: 68C/154.40
Core #3: 70C/158.00
Specs of my PC
i5-3570k OC 4.4GHz: I did NOT try to go higher yet. I'm not liquid cooling yet either.
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504
MSI-Z77A-G45
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130645
G-Skill Ripjaws 8GB DDR3 1333/ OC to 2000MHz
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231311
XIGMATEK LOKI SD963 92mm HYPRO Bearing CPU Cooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233081
GeForce GTX 660 2GB 192-bit GDDR5 PCI Express 3.0 x16
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130826
Arctic Silver 5
http://www.newegg.com/Product/Product.aspx?Item=N82E16835100007
YouTube Link below
Tips:
Running at 4.4GHz
Temps below
Core #1: 83C/181.40
Core #2: 68C/154.40
Core #3: 70C/158.00
Specs of my PC
MSI-Z77A-G45
Arctic Silver 5
