CPU: AMD FX-6300 3.5GHz 6-Core Processor
Motherboard: Asus M5A97 LE R2.0 ATX AM3+ Motherboard
Memory: G.Skill Ares Series 8GB (2 x 4GB) DDR3-1600 Memory
Storage: Western Digital Caviar Blue 500GB 3.5" 7200RPM Internal Hard Drive
Video Card: PowerColor Radeon HD 7850 2GB Video Card
Case: Cooler Master Elite 430 - Mid Tower Computer Case with All-Black Interior (RC-430-KWN1)
Power Supply: Corsair Builder 600W 80 PLUS Certified ATX12V Power Supply
Operating System: Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit)
Optical Drive: Lite-On Super AllWrite 24X SATA DVD+/-RW Dual Layer Drive - Bulk - IHAS124-04 Version C (Black)
This is my computer build for my gaming rig. I want to add a sentry 2 fan controller the a 5.25 Bay Drive. I believe my motherboard can have 3 pands based on the amount of connectors to the fans, but, with this Sentry 2 from NZXT can I add a 4th fan? Does the Sentry 2 disperse power to each fan? I assume it does because the fans will have to be connected to the Sentry 2 for control. Also, I have the Red LED sickle flo 120mm fans, will those work with the Sentry 2?
http://www.newegg.com/Product/Product.aspx?Item=N82E16811992005
Above link is to the Sentry 2 on newegg. ANY HELP is appreciated! I just want to see if I can run 4 fans on this Sentry 2 with my current build and was interested in any info about it.
