Ok I just got a new GPU... ATI Radeon HD 4850 Toxic.... it is working fine all the time but when I play a game for a while my screens goes black or in some other colour with white stripes and the it the monitor shows me No Signal on my dvi cable, it goes black and it turn offs(HP 2311x).. I don't think the monitor is the problem..... Then I have to restart my computer... It is not an overheat problem because all the temperatures are fine... CPU 39° - 50° and same for the gpu... only problem with my gpu is that when I looked at the GPU Diode(MemIO) the temp is really high 50-60°on idle and 90-110°on full load... anyway I want to know is my psu strong enough and what is the problem with all of this... This started to happen after I got the GPU but the GPU worked just fine on my cousin's pc.. so here are my specs.. and helpp meee!!
CPU: QuadCore AMD Phenom II X4 Black Edition 965, 3400 MHz (17 x 200)
MBO: ASRock M3N78D FX (3 PCI, 3 PCI-E x1, 1 PCI-E x16, 4 DDR3 DIMM, Audio, Gigabit LAN)
RAM: G Skill F3-10666CL9-4GBNT, 4 GB DDR3-1333 DDR3 SDRAM (9-9-9-24 @ 666 MHz) (8-8-8-22 @ 609 MHz) (7-7-7-20 @ 533 MHz) (6-6-6-17 @ 457 MHz)
GPU: SAPPHIRE TOXIC HD 4850 512MB GDDR3 PCI-E
PSU: Corsair Builder Series CX430
SSD: OCZ-AGILITY3 ATA Device (SATA-III) - my windows installed and some all the program files on it
HDD; WDC WD5000AAKX-001CA0 ATA Device (500 GB, 7200 RPM, SATA-III) - all the games, movies, music etc...
Monitor: HP 2311x (Analog) [23" LCD] (3CQ140NSZ7) - as I said.....
