Hello,
I'm building a new pc using the Asus M5A97 LE R2.0. Here are the specs at the egg: http://www.newegg.com/Product/Product.aspx?Item=N82E16813131872
It has 2 USB3 ports in the back and no header on the board, and the case I'm using has USB3 in the front. The question then is: if I get a USB3 pci card, what kind of speed can I expect? This isn't a case where the board is all USB2 and I'm trying to add a newer technology. This board has built-in USB3 controller just no header. The board has several pci slots but the fastest pcie will be occupied by the graphics card.
Anyone has any experience with this? Any brand they can recommend?
Thanks
Thanks
