I have just upgraded a Dell XPS 630 including replacing the stock motherboard with an ASrock Z77 Pro3.
As soon as I plug in the AC power cable, the PC boots - without using the powerbutton. When I try to turn it off using the normal Start-Shutdown sequence it powers down normally, shuts down (no noise from fans/drives) and then a couple of seconds later boots up again.
Does anybody have any suggestions on what could be causing this problem ?
Everything else appears to be running fine. I'd appreciate any help.
