Looking for low priced 120mm case fans
Last response: in Components
- Looking for low profile 120mm radiator case fans - Forum
- Looking for a High CFM/low DBA 120mm Case fan... does it even exist? - Forum
- Looking for good 120mm and 92mm case fans. - Forum
- Best Price per Performance 120mm Case Fans? - Forum
- Some decent 120mm case fans for a decent price? (3 pin) - Forum
- Looking for the Quietest 120mm Case Fan I can get with Equivalent Cooling Forum
- Solvedlooking for a low budget case fans Forum
- SolvedBest cheap 120mm case fans? Forum
- SolvedIs Noctua the best for 120mm case fans? Forum
- SolvedLooking for best 140mm and best 120mm fans. Forum
- SolvedFill a case with Silent 120mm and 140mm Fans Forum
- SolvedWhat are the best 120mm case fans with blue LEDs? Forum
- SolvedNZXT Phantom case, can I install two extra 120mm fans? Forum
- SolvedCase fans 140mm vs 120mm Forum
- SolvedBest 120mm and 200mm Case Fans Available. Forum
- SolvedReplacing NZXT FN V2 120mm case fan on H440 case Forum
- SolvedBest 120mm and 140mm green led case fans Forum
- quality of cyberpowerpc 120mm case fans Forum
- SolvedMounting additional 120mm case fans on Corsair 400R Forum
- Solved120mm Case Fans Forum
- More resources
Read discussions in other Components categories
The problem was that my GPu started to fail on me. Games randomly froze and I got a BSOD or I got rebooted to my desktop with the message; ''AMD Driver has stopped working and has been recovered''. Someone told me that it could have been my GPU overheating. Since then I've started using MSI Afterburner for a higher fan speed, and got a brand new case, since my old one had no airflow whatsoever. It only had 1 exhaust fan on the back, and the PSU was odly placed in the top-back corner, producing even higher temps in the case. I had one of those PCI GPU coolers like you suggested, but it did not help, because it only blew the hot air of the bottom of the case back in the GPU. It made like a difference of maybe 1 or 2c. And it made a LOT of noice.
