Upgrading from Radeon HD 4870 X2 to eVGA GForce GTX670 FTW Power Supply Questions
  • EVGA
  • Power Supplies
  • Graphics
  • Graphics Cards
  • HD
  • Radeon
June 7, 2013 11:28:20 AM
Ok as you can see I am planning on upgrading my video card. Looking to better understand the GTX670 power requirements. It says it requires 30A on the 12V rail. I need to understand if it required a total of 30A for both supply lines or more like 15A per connector.
Here is the reason. My current 700W supply has 5 - 12 outputs each rated to 18A. If I need 30A on each 6 pin connector on the video card I will have to see if I can parallel up to see if can double the current. That will depend on the how many transformers I have.
Anyway if the spec really is 15A per connector and 30A per the 12V main my 18A outputs can simply be plugged in with no concern.
So what I am asking is can I supply the 670 with two 12V sources rated at 18A each?
Thanks.....my first post here........
More about : upgrading radeon 4870 evga gforce gtx670 ftw power supply questions
June 7, 2013 2:32:08 PM
Ok here's the poop for those that may need similar information. I assumed this but verified with technical support at eVGA today. The power supply spec of 30A on the 12V rail is split for each 6 pin PCI-E connector.
Therefore you need only 15A from each side of the card making my 18A sources capable of sourcing.
Funny my first post and I have to answer it myself.......
