Approximate Purchase Date:3 months
Budget Range:2000-3000
System Usage from Most to Least Important:Gaming and watching movies
Are you buying a monitor: No
Do you need to buy OS: No
Preferred Website(s) for Parts: newegg.com, amazon.com (free shipping)
Parts Preferences: Intel CPU, ATI GPU
Overclocking: Yes
SLI or Crossfire: Yes
Your Monitor Resolution: 1920*1080
Additional Comments: Pretty much a futeproof gaming monster with little regards to human health or safety. Also I have an APO box so shipping from amazon is free but newegg likes to add a lot in shipping costs there.
And Most Importantly, Why Are You Upgrading: Old PC just not cutting it.
So the parts I have picked out are as follows:
CPU: Intel Core i7-3770K 3.5GHz Quad-Core Processor
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116501
Memory: Corsair Vengeance 16GB (2 x 8GB) DDR3-1866 Memory
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233278
Motherboard: ASRock Z77 Extreme6 ATX LGA1155 Motherboardhttp://www.newegg.com/Product/Product.aspx?Item=N82E16813157295
Or ASUS SABERTOOTH Z77 LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard http://www.newegg.com/Product/Product.aspx?Item=N82E16813131821
GPU:Sapphire Radeon HD 7970 GHz Edition 6GB Video Card (crossfire)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814202005&Tpk=Sapphire%20Radeon%20HD%207970%20GHz%20Edition%206GB%20Video%20Card&IsVirtualParent=1
Power Supply:COOLER MASTER Silent Pro Gold Series RSC00-80GAD3-US 1200W ATX 12V v2.3 / EPS 12V v2.92 SLI Ready CrossFire Ready 80 PLUS GOLD Certified Modular Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817171055&Tpk=Cooler%20Master%20Silent%20Pro%20Gold%201200W%2080%20PLUS%20Gold&IsVirtualParent=1
My biggest concern is that the GPU takes up a lot of room. I'm wondering if there is a motherboard out there I can use to crossfire those and still have room for a sound card. I have a nice pair of headphones I would like to take advantage. Everything else is set in stone as to what I want but I will take advice on the things I have listed as well as a good sound card. I have 5.1 speakers and my headset is high end. Also advice to save money here and there to make it work sounds good as well. This is my first build so any advice would be awesome.
Overclocking: Yes
