Hello!
I am trying to find a good aftermarket cpu cooler for my Phenom II x4 965.I was suggested to get Hyper 212 Evo,which is probably not going to fit in my case(Coolermaster K280),so i am thinking about the AC Freezer 7 Pro Rev 2.From what i have read so far,it's not as good as 212 Evo.I also read there is a problem with AM3 chips,that the contact surface is not covering the face of the chip.Is that true?Also,will i get better temps than my stock cooler(~40 idle,even 68 full load,60-61 after re-applying thermal paste)?I have not overclocked it and i am not going to.Any other cooler i should consider that is good for this cpu?
Thank you!
Thank you!
