As the subject says, looking to reduce my loop to increase the flow pressure which I've noticed can be improved in both my CPU and GPU loops (brass weights in my res that measure flow have dropped over time).
Thinking my best move would be to sever off the drain ports in favor of a T-joint with a valve - that way when I need to drain it (rarely) I can just screw in a tube to the valve and open it up..
Appreciate the input!
Here is the PDF to my rig and before after diagrams:
http://
Here is a like to my build site which tells my parts list (its dated but my WC parts are the same)
http://
http://
http://
