Power on problem
  • Battery
  • Laptops
  • Green
  • Power
  • Components
Last response: in Components
June 21, 2013 11:09:17 AM
When I press the power button to turn my laptop on the green light comes on momentarily but then goes out and nothing else happens. I thought maybe I had a battery problem but I replaced the battery and that didn't change the symptoms. Please help...
More about : power problem
June 21, 2013 11:42:42 PM
take out the battery, only plug hte power adapter in, and hold the power button and tell me what happens.
June 22, 2013 12:21:43 AM
I did as you instructed and had the same result the power light comes on temporarily and goes off. I tried holding the power button down as well no help...
June 22, 2013 12:31:41 AM
ok with the battery still out of it, unplug the charger from the lap top. hold the power button for about 30 seconds. let go of the power button. put the battery back in and try it again.
June 22, 2013 1:08:30 AM
Tried that same result power light comes in temporarily then goes out...
June 22, 2013 1:11:32 AM
what brand and model laptop do you have?
June 22, 2013 1:30:41 AM
Acer aspire 5601AWLMi
