sfc scannow command problem
anon_private
63
I am trying to use sfc / scannow.
I cannot boot Vista so I am using the Dell Vista installation disk, and its command prompt utility.
When I try to use sfc, I get the message: 'Windows resource protection could not perform operation'.
Can someone tell me how to overcome this problem?
If I can scan, how can I initiate repairs?
Thanks
If the Dell disk doesn't land you in C:\ at the Command Prompt, it may be using a RAM drive or showing the directory of the optical drive. Use the command c: then press Enter and try sfc /scannow at the C:\ prompt.
anon_private
63
Thanks for responding.
I tried your suggestion, but I am still seeing the message: 'Windows resource protection could not perofrm operation'.
Best wishes.
A'
