Is this cable going to be a problem in terms of heat?
  • Cable
  • Heat
  • Heatsinks
  • Components
  • Power
Last response: in Components
June 24, 2013 8:07:33 PM
There is a cable that appears to be stuck between the the power input and heatsink of my card (gtx 670 PE), is this ok or should I try to wedge it out?
http://s11.postimg.org/pe9i8pvir/20130624_230057.jpg
This is my first build and I just don't want to screw anything up too much, so sorry if this question is naive.
Thanks in advance guys
More about : cable problem terms heat
June 24, 2013 8:33:56 PM
anyone?
