Looking for a Solution in my Hard Drive...
  • Hard Drives
  • Windows
  • Seagate
  • BIOS
  • HD
  • Windows 7
Last response: in Windows 7
June 26, 2013 3:00:57 PM
What will i do? if my Seagate 500gb sata HD is detected in Bios and in Windows, But my Seagate 1TB HD is now not detected in BIOS and Windows all my back up files was there...it's Just gone when i open my PC unit... PLS NEED YOUR HELP....
Thank you in Advance.... :)
More about : solution hard drive
a b $ Windows 7
June 26, 2013 6:31:31 PM
Did you just reinstall Windows on the 500?
June 27, 2013 5:45:26 PM
Yes sir i just did...and do the troubleshooting but nothing works... ive just got back to the mall where i buy the Hard drive.. they tested it to but the hard disk was not responding.. and they replace it with the new one.. so now im back to zero... :(
