Approximate Purchase Date:
Budget Range: $2,000-2,400
System Usage from Most to Least Important: gaming.
Are you buying a monitor: yes
Do you need to buy OS: Yes (prefer windows 7, unless there is a plus to using 8.)
Preferred Website(s) for Parts: newegg and amazon.
Location: holland texas (20 miles away from temple texas.)
Parts Preferences: none, as long as it will work.
Overclocking: No.
SLI or Crossfire: yes, in the future definitely.
Your Monitor Resolution: 1920x1080
Additional Comments:i will be playing the new star wars battlefront, battlefield 4, EVE online, mirrors edge 2, and warframe. i do NOT want liquid cooled, i would like a case that can fit a LOT of fans if possible.
i have been contemplating whether or not to go through falcon northwest or to build my own, the price of one of their desktops i designed was 2.4k, just want to see if i can get the same stuff, or better stuff for the same price or cheaper.
And Most Importantly, Why Are You Upgrading: the laptop i was using cannot run any games.
thank you in advance for whoever helps!
Overclocking: No.
