Computer Won't Load After Power Surge
  • RAM
  • Power Surge
  • CPUs
  • Computers
Last response: in CPUs
July 9, 2013 10:38:56 PM
So I received a PC that had a problem with a power surge and it load properly. Here are the symptoms:
1) PC turns on, and all fans spin perfectly
2)HDD runs perfectly
3)RAM works
4) MOBO gives off 1 beep
5) Screen gives the options to "BOOT normally", or "Run Repair Mode"-But then neither option works, it just goes in a loop.
6)MOBO does allow for F12, and allows DEL-ENTER SETUP
7) Screen says "No Signal"
Also, mind you this is using Integrated Graphics
Steps Taken:
1) I have replaced the PSU with a new one
2) I tested out all 3 RAM sticks, as well as placing in 2 other new sticks of RAM.
3) I have placed the HDD in my own PC and everything loads up perfectly.
At this point I feel like it's the CPU, and not the MOBO, but I'm not sure.
More about : computer load power surge
a c 158 à CPUs
July 10, 2013 3:56:15 PM
disable automatic restart on error andf boot up normally again and check what error message you get.
Off hand I'd say you just have a corrupt driver that isn't used whn the hdd is in your system. If that not it then I'd say system board.
a b à CPUs
July 10, 2013 11:11:32 PM
CPUs rarely fail, so it's probably the motherboard.
July 12, 2013 9:54:35 PM
the HDD is working perfectly fine. I've loaded it up onto my own pc, and everything works perfectly. The OS is present and functional and all files open up without a hitch.
July 12, 2013 9:56:36 PM
Yeah I can't tell if it's the CPU or the MOBO yet. The only reason why I was thinking it was the CPU is because the MOBO gave me the correct number of beeps, and everything else still turns on and spins, which I kind of figured meant that it's sending the proper signals to the proper places.
a b à CPUs
July 12, 2013 10:10:50 PM
Again, CPU's very rarely fail. They are robust little buggers. So most likely it is your motherboard.
