I have an Nvidia 8800 GTS in a Win 7, 64 bit configuration. When I boot, only one monitor displays. In the Windows configuration window, both monitors appear, but the non-displaying monitor is grayed out. It can be selected, but the resolution and orientation are disabled. The 'multiple displays' box only allows display on one monitor or cloned. If you select 'Extend' and 'Apply', it reverts back to 'display on monitor 1'. I put in an Nvidia 620 card, but experienced the same results. Suggestions?
