Sign-in / Sign-up
Solved
Best 27 inch monitor for an msi 660ti power edition
  • Power
  • Graphics Cards
  • Monitors
  • Graphics
  • MSI-Microstar
Last response: in Displays
July 17, 2013 5:54:32 AM
I am looking for the best monitor (under 400$) for the stated video card. The games played are mostly league of legends and civ 5. I save my fps and higher end stuff for console so that's not a consideration. Moving up from a Dell s2409w. Thanks.
More about : inch monitor msi 660ti power edition
Best solution
a b U Graphics card
a b C Monitor
July 17, 2013 6:18:27 AM
The VH278HE is the fastest monitor I've ever seen. Quality isn't very good though. If speed if you main concern, get that. If you want quality (and still very fast pixel response) get the ASUS PB278Q.
a c 187 U Graphics card
a b C Monitor
July 17, 2013 6:27:50 AM
Asus VE278Q 27-Inch Full-HD LED Monitor
Asus monitors are widely used in the professional gaming community because they generally have some of the lowest input lag available. Details include a 1920 x 1080 resolution / 10M:1 DCR/ 2ms response/ DisplayPort, DVI-D, D-Sub, HDMI/ Tilt adjustment / and 2 x 3W speakers.
http://www.amazon.com/gp/product/B0043T34RK/ref=as_li_q...
m
l
a b C Monitor
July 17, 2013 6:30:12 AM
Agreed if you can afford it.:)
m
l
a c 100 C Monitor
a c 91 U Graphics card
July 17, 2013 6:32:48 AM
In U.S? You might be able to snag a good 1440p Korean monitor.
m
l
July 17, 2013 6:34:37 AM
The ve model is one I'm looking at. Also at the low end was looking at an aoc that's on sale for 199(e2752vh). At the high end was looking at the $390 2560x1440 from monoprice but I worry that with my video card the fps would be horrible. I don't have the knowledgeto make that call though.
m
l
July 17, 2013 6:35:34 AM
Yes US based.
m
l
a b U Graphics card
a b C Monitor
July 17, 2013 6:37:49 AM
Well if it doesn't need to be 27" / 1440p then I'd strongly recommend the PA248Q or PA238Q/PB238Q. Or the MX239H. And I'd agree that your card is better-suited to 1080p gaming.
m
l
