This week I built my first gaming system (<£500):
AMD FX-6300
XFX 7870 DD GHz edition
ASrocks 960 GM U3S3
8 GB 1600 MHz Crucial Ballistix Sport (2x4GB)
2TB
Zalman T1 case
Chieftec Smart series 600W PSU
Fans:
2 x 120mm Cooler Master Silent Fan 120 SI1
2 x 92mm Coolink SWiF2-920
1 x Zalman TM1 standard 92 mm fan
My grahics card is reached 100 degrees C yesterday after trying it with Skyrim on Ultra setting after about 1hr of gameplay. I have 5 fans installed (1x92mm back exhaust, 2x92mm side exhaust, 1x 120mm front, and a 1x120mm top exhaust)
Can anyone help me with suggestions on how to reduce the GPU temperature? Do I need better fans? Are the GPU fans at fault?
N.B Because of the motherboard design the space between the PSU and the GPU is only bout 2 inches, will this affect the cooling?
I'll be thankful for any help you can give me
Thanks very much
AMD FX-6300
ASrocks 960 GM U3S3
2TB
Zalman T1 case
Fans:
Thanks very much
