Hello All,
My girlfriend and I are close to buying a house (everything is in contract and seems to be going well) and I have been thinking of how to run our network.
The house - 970sq ft with a full, unfinished basement. About 5 rooms and a bathroom (2 rooms are very open (living room and kitchen/dining) and then 3 relatively equal sized bedrooms). The basement has a drop ceiling installed, and I plan to finish half of it to build 2 more rooms (an office and workshop), and a small room like the size of a walk in closet or bathroom.
The network - I will most likely be buying a 1000ft spool of wire (as it seems cheaper than buying a 3-4 100ft cables) and I do plan to do CAT6 (future proof, yeah!). I have a few CAT6 and CAT5e 25-50ft cables, but I planned to just run them through walls or something to the devices in the basement as they will be easily accessible 80% of the time (probably above between drop ceiling and floor joists). Wireless setup is a N750 Dual Band Netgear (WNDR4000?) Gigabit router. Attached to the router is an 8 port Gigabit switch, a Wireless B access point (connected by ethernet obviously) and a D-Link Dual Band (Gigabit I think...) Media Bridge (connects a Blu-ray player to my wireless 5ghz signal).
My thoughts are, so far, to have the Netgear router and switch in the office (basement). Then everything will be wired from it... N750(hub) will have a wired connection running to one room over (workshop/basement) to the Wireless-B router as this is the main area of the house I will have B devices running. It will have a wired connection to the 8 port switch which will be in the office to wire in 3-4 PCs. The D-link bridge will connect to the router wirelessly, but I will need to run 4 wires from it for streaming devices (one to the living room, and one to each bedroom (3)... can I run a switch off a bridge to connect more devices to the 5ghz band??).
So, my questions I am facing...
1. Will the N750 router give me good coverage on the first floor with it being in the basement and having the floor joists and drop ceiling between it and a first floor wireless device (ie: the bridge or laptop).
2. If the N750 doesn't give good coverage, I assume I should buy another router to run wired from the N750 to the first floor acting as access point. Do I lose bandwidth plugging the new access point into the switch rather than directly into the N750 router? Also, since the N750 is dual band it is 300mbps for the 2.4ghz band and 450mbps for 5ghz band, so if I use a 300mbps router as the new access point for 2.4ghz devices will I hinder the performance of my Wireless devices or the N750 router? (I've read if I use a 150mpbs device on a 300mpbs router, all devices connected to the router performs as if the router is 150mpbs). Will being Gigabit or not make a difference in performance (since it is only for wireless on the first floor).
3. (the BIG one..) What would be the proper wire type (plenum, riser, stranded, solid core, etc.) for these different setups or does it matter? I don't know if I plan to do wall plates.. I'd like to hide all wires as much as possible, so I do plan to go through the drop ceiling and floor and into walls. But, I like the idea of some slack being able to be pulled out of the wall (like a cable company will do so your TV is not stuck in one spot only in the entire room).
4. What is your opinion on this setup? Haha. Just looking for comments on how optimal/strong this setup will be.
Thanks for all the help.
