Wifi problem it won't connect
  • Connection
  • WiFi
  • Internet
Last response: in General Connectivity
July 18, 2013 3:12:22 PM
About 10 mins ago we changed our username for wifi so we can identify it easier so I did that and Internet went off like it said it would do and I restarted it and the name got changed and connected to it so we changed the password and did the same restart it and when it is on it can find the wifi but won't connect to it now
More about : wifi problem connect
August 1, 2013 12:23:15 PM
You changed the wifi name and the password and now can't connect? I'm guessing you are either connecting to the wrong wifi name or using the wrong password. You're other issue is the total lack of writting in proper form which is why I'm guessing no-one has replied to the post yet.
Delete your exsting connections (there should be a "forget" option or something similar in the wifi settings on the computer), and connect to your new wifi name and password.
