I'm having this strange problem with my motherboard or GPU or CPU on the computer i build just 2 weeks ago.
Specs:
AMD FX-8350 4.0GHz 8-Core Processor
Gigabyte GA-990FXA-UD3 ATX AM3+
Patriot Viper 3 16GB (4 x 4GB) DDR3-1866 Memory
Western Digital Caviar Black 1TB 3.5" 7200RPM
PowerColor Radeon HD 7850 2GB Video Card
Cooler Master Storm Scout 2 (Black) ATX Mid Tower Case
Cooler Master GX650W 80PLUS Bronze PSU
Details:
The PC boots okay, but after a random period of time, the screen goes blue says NO HDMI SIGNAL then turns off. THE PC IS STILL RUNNING. (ASUS VS247 24" LED Monitor).
So i thought it was the monitor and i switched it out and tried an old 18" BENQ monitor that i had. It ran for a while but then it shut off again just like the other one.
I don't know if this is relevant or not, but when i usually press my power button on my case, the PC shuts down. But after the display goes off, if i press the PWR button, it doesn't and i can't see what's going on because i have not display.
I thought it was just a bad HDMI cable and i tried to use another one but no luck. I'm using the latest AMD CCC drivers.
After the display goes off, the fan are turning. When the display goes off there's no warning or anything, the screen just goes blue says, "NO SIGNAL - HDMI" and goes into sleep. I turn it off then on, still no luck.
Temps are not the problem.
I tried the GPU is different PCI-e slots but the problems still persists.
The power settings on Windows are fine (it's on maximum).
Specs:
Details:
