Is the FX-990 R2 3-pin connector (Digi+ EPU) where I put the cooling pump connector?
  • Water Cooling
  • Power
  • Cooler Master
  • h110
  • 3-pin
  • CPUs
  • Asus
  • Cooling
  • Corsair
  • pump
  • fx-990-r2
  • Motherboards
July 27, 2013 10:26:06 AM
Sabertooth Asus FX-990 R2 MB.
Used a Corsair H110 liquid cooler.
I guess the 2, 4-pin fan wires, plug into the CPU and CPU OPT connectors on the MB.
But what about the 3-pin pump wire?
There is a 3-pin connector very close to the CPU connectors, but it is unlabeled. In the manual it suggests this is a connector for fine-tuning voltage for a CPU/DRAM, but I am nervous about using it.
Does anyone know?
Thanx!
Zeddock
More about : 990 pin connector digi epu put cooling pump connector
