Does water cooling your CPU make a big difference for overclocking?
  • Overclocking
  • Water Cooling
  • CPUs
a b à CPUs
August 1, 2013 1:43:10 PM
I'm thinking about getting a Cooler Master Water Cooler for my FX-8350 and FX-8320. How much does it help in terms of overclocking?
More about : water cooling cpu make big difference overclocking
a b K Overclocking
a b à CPUs
August 1, 2013 2:16:14 PM
It may. there a section in the water-cooling sticky for close loops liquid cooling, I don't recommend anything below an H 100.
But these closes looped system are no ware near as good a actual water-cooling. what are you currently using for cooling you CPU now?
a b à CPUs
August 1, 2013 2:18:55 PM
I currently use a Cooler Master Seidon 120M.
a b K Overclocking
a b à CPUs
August 1, 2013 2:25:46 PM
ok so now I am confused you want to replace it with what?
a c 103 K Overclocking
a b à CPUs
August 1, 2013 5:37:45 PM
Depending on how far you want to go with overclocking will make a difference in the answer to your question. Seeing as how we really don't know your intent, difficult to give a proper answer. The are air coolers that perform far better than closed loop coolers, and of course for max cooling capacity custom loop options.
Question is - What do you want to be able to do?
