You could place some paper insulation around the drive if you suspect that the PCB is touching something.
However, I suspect that there may be a connection problem that shows up when the PCB is under stress. If it's a WD drive, then remove the PCB and clean up the HDA contact points on the PCB with a soft pencil eraser. Sometimes the oxidisation causes problems with the preamp inside the HDA.
