Hi,
I am currently having a problem where my computer just reboot when I play intensive game (Bordelands 2,3dsmark, etc). The problem is recent. I don't know if it's the power supply or the video card ? Any suggestion on test I could run that would help me troubleshoot the problem ? I have a spare GTX 460 I can use to test.
My spec a are
Windows 7 Home premium 64 bit
CPU intel Core i7 4770K
Motherboard: Gigabyte Z87X -UD3H
GPU MSI Gaming N760 TF 2GD5
Power supply: Corsair HX 750
Memory 16 gig CORSAIR Vengeance 1866
1 SSD + 3 hard drive + 1 Bluray writer
I have the latest Nvidia driver (I did not try the Beta yet)
I ran a window memory test and it found nothing (just in case). I underclock the GPU it help a bit. I also setup the GPU fan to be more aggressive when it hit certain temperature. I setup a automatic logging to file of the Temperature, clock speed, voltage. The temperature look normal. I am around 60 celcius when it reboot. I think that's normal.
Any help would be appreciate.
Thanks.
My spec a are
Thanks.
