Fixing the buzzing or ringing noise in headsets - possible solution
glennjh66
I had this common problem as well. The headset jack for me is on the right hand side of the laptop at the front. Next to the headset port are 2 USB ports where I had my external mouse plugged into. By chance, while wearing my headset, I unplugged the external mouse and the buzzing disappeared. Luckily I have a USB port on the left hand side as well where I can plug the mouse into with no noise. For me it was an external peripheral. Check that first.
Good luck
Meoricin
107
As I understand it, it's basically electrical interference around the audio channels/transmitters.
I resolved similar on my motherboard by buying a sound card.
