Is my current build good? Also, question about a power supply.
  • Build
  • Power Supplies
  • CPUs
  • Systems
Last response: in Systems
August 8, 2013 6:07:11 PM
More about : current build good question power supply
August 8, 2013 7:02:20 PM
bump
August 8, 2013 7:06:16 PM
The Power Supply will come with all the power cables, the motherboard will come with the sata cables for your optical drive and HDD. If you want to add a Video Card in the future I would recommend a 650W Power Supply, if not, get a 450-550W PSU
August 8, 2013 7:14:29 PM
I forgot about the GPU. http://www.newegg.com/Product/Product.aspx?Item=N82E168...
