This is my first build so I dont have any expierence with fan orientation. Ive done some research and it seems there is no one answer, especially with different fan configurations even with the same case. My case is the NZXT Phantom Full Tower. I have the side window panel so my cooling options are :
140mm intake in front
2 120mm intake on the side
2 200mm exhaust on top
Corsair h80i in the rear.
With my fans, assuming the positions i plan to use them in are correct, what would be the best option for orientating the h80i in the rear?
