First of all.I am sorry if thisis the wrong section.
But here are my parts and i was wondering if they all are compatible.
Any further help is much appreciated!
Here are the specs:
700 Watt
Case: CFI Boreallight Full-Tower Gaming Case w/ 1x 140 & 2x 120mm Fans, Front USB 3.0, HDD Easy Swap Bays & Side-Panel Window (Black Color)
Extra Case Fan Upgrade: Maximum 120MM Color Case Cooling Fans for your selected case (Red Color)
CPU: Intel® Core™ i7-4770K 3.50 GHz 8MB Intel Smart Cache LGA1150 (All Venom OC Certified)
Venom Boost Fast And Efficient Factory Overclocking: Extreme OC (Extreme Overclock 20% or more)
Cooling Fan: Asetek 510LC Liquid Cooling System 120MM Radiator & Fan (Enhanced Cooling Performance + Extreme Silent at 20dBA) (Single Standard 120MM Fan)
Coolant for Cyberpower Xtreme Hydro Water Cooling Kits: Standard Coolant
Motherboard: [CrossFireX] MSI Z87-G41 PC Mate Intel Z87 Chipset DDR3 ATX Mainboard w/ Military Class 4, OC Genie II, 7.1 HD Audio, GbLAN, HDMI, 2 Gen3 PCIe x16, 2x PCI-e & 2 PCI (Pro OC Certified)
Memory: 8GB (4GBx2) DDR3/1600MHz Dual Channel Memory (ADATA XPG V2)
Video Card: NVIDIA GeForce GTX TITAN 6GB 16X PCIe 3.0 Video Card (Major Brand Powered by NVIDIA)
Power Supply Upgrade: 700 Watts - Cooler Master i700 700W 80 Plus Bronze Certified Active PFC Power Supply
Hard Drive: 1TB SATA-III 6.0Gb/s 32MB Cache 7200RPM HDD (Single Drive)
External Hard Drive (USB3.0/2.0/eSATA): None
Optical Drive: 24X Double Layer Dual Format DVD+-R/+-RW + CD-R/RW Drive (BLACK COLOR)
Sound: HIGH DEFINITION ON-BOARD 7.1 AUDIO
LCD Monitor: 22" Widescreen 1680x1050 TFT Active Matrix LCD Display
Network: Onboard Gigabit LAN Network
Keyboard: Razer BlackWidow Ultimate 2013 Mechanical Gaming Keyboard w/ 5 customizable macro keys
Mouse: Microsoft Explorer Optical Mouse
Headset: Corsair Vengeance 1500 Gaming Headset ([H]ard|OCP Editor’s Choice Gold Award)
Wireless 802.11 B/G/N Access Point: None
IEEE1394 Card: None
Internal USB Port: Built-in USB 2.0 Ports
USB Port: Connectland USB 2.0 HUB High Speed HUB
Thank you for your time
I am new to this so sorry if i messed up :/
Tell me what you think about my gaming rig its worth about 2000 dollars
Here are the specs:
700 Watt
IEEE1394 Card: None
