Sign-in / Sign-up
Solved
new custom pc build freezing and now monitor has no signal
  • AMD
  • Monitors
  • Build
  • Graphics
  • Help Desk
  • New Build
Last response: in Displays
August 15, 2013 8:02:09 AM
hi everyone im brand new to the form I am running a new build and am having some problems I have tried many things and researched for hours um my computer is
a
MSI 970A-G43 AM3+ AMD 970 SATA 6Gb/s USB 3.0 ATX AMD Motherboard
MSI N650ti-2GD5/OC BE GeForce GTX 650 Ti boost graphics card
CORSAIR Enthusiast Series TX650 650W ...
Western Digital WD Blue WD5000AAKX 500GB 7200 ...
AMD FX-6300 Vishera 3.5GHz (4.1GHz ...
Antec Three Hundred Black Steel ATX Mid Tower ...
with 4 gigs of rip jaws ddr3 ram need more ram I know
so I built my computer it ran great then I played multiple games and the whole entire screen would freeze and this progressively got worse and then me and my friend upgraded the drivers multiple times had some problems in the bios when we updated that we eventually thought because the monitor output is coming from the graphics card with a hdmi the g card was malfunctioning and eventually we replaced it just came back from Newegg a few days ago with a replacement I have monitored it with a lot of stress tests and heat monitors and am still having the problem except now it wont show anything on the screen once I upgraded AND REPLACED MY POWER AND GRAPHICS CARD SORRY FOR THE CAPS IM LAZY AND DOONT FEEL LIKE RETYPING IT LOL SO THATS IT HOPE U CAN HELP
temps are running good and normal and everything was great but now its just 1 problem it wont turn on
ps. I touched a bit of thermal paste when building it and I thought that might be some help so that's all I have also I am running win 7 pro thanks have a great day
More about : custom build freezing monitor signal
Best solution
August 15, 2013 8:18:30 AM
You appear to have a hardware problem. Unfortunately, there's only one way for folks like us (who don't have access to a laboratory) to troubleshoot such problems. That is to replace suspect components with known good ones until the problem is located. Good luck.
