Hi,
I have a HP Compaq G56 laptop. Last week the screen started going black intermittently with the computer still running. I used a flashlight to check if the backlight had gone out and everything was still on screen. I put some pressure on the plastic bezel below the screen and on the corner of the keyboard and it came on again. It did this continuously for a while then it did shut down. It was getting very hot even the keyboard was heating. I switched it back on again and it said it was a thermal shutdown. I figured that the fan needed replacing as it just seemed to remain at the same low speed all the time so I bought a new fan and installed it but the screen going black is still persisting. Any ideas or feedback would be really appreciated.
Cheers.
Cheers.
