Hello,
I've noticed a Maximum TDP (Thermal Design Power) limit on a Motherboard of 95Watt. Is this for the CPU only, or does this limit apply to the GPU too?
Does this effect the performance of the Graphics Card if the TDP of the card exceeds that of the main board?
For example: The case of the nVidia GTX650Ti (TDP 110W)
Thank you!
(Also, thanks for the great site - I always refer to it for tech info!)
Thank you!
