Problems with monitor display
  • Monitors
  • Graphics Cards
  • Motherboards
  • Graphics
  • Displays
August 18, 2013 1:56:50 PM
I'm using a Asurs HD6670 graphics card but my monitor won't seem to show anyhng, yes there's power going to each as the fan works on the card and there is the standby light on the monitor. I tried a different monitor and the same problem occurred.
I replaced a new motherboard fan but I didn't really know we're to put the wires back. After a while I got most in the right areas with logic and the manual's help. Is it possible that I'm missing a wire or not got the wire in the right place that's effecting the monitor?
Motherboard- ASrock n68c-gs fx
Anyone got some ideas?
Here are some images on my PC, hope they are clear enough to use.
http://s8.postimg.org/uvd42h1it/image.jpg
http://s8.postimg.org/z33axhdkl/image.jpg
http://s8.postimg.org/ycakrpb79/image.jpg
Thanks.
More about : problems monitor display
a b U Graphics card
August 20, 2013 8:01:43 PM
Did you switch the Video out in the BIOS to PCI
