I just replaced my crappy DSL modem with a new Comcast modem (30mb/s Down, and 5 mb/s Up)(yay!) and connected it to a router(linksys e1000). Tested at seperate times, Computer A is closest to the router and gets 30mb/s down and 5mb/s up while computer B is alot farther than the router and gets 20 mb/s down and 0.5 mb/s up, but when I plug Computer B's ethernet cable directly into the comcast modem it gets 30mb/s Down and 5 mb/s Up. I'v tried two different routers now and computer B still has different speeds as computer A. How do I make it so they both have the same speed?
Computer A (older)(30mb/s down and 5mb/s):
Ethernet cable - 1 feet from router
Cable type: CAT V
Motherboard: unknown, really old motherboard(uses ddr2 ram that old)~
Computer B (newer)(16 mb/s down and 0.5 mb/s up):
Ethernet cable - 15 feet from router
Cable type: CAT V
Motherboard: ASRock Z77 Extreme4 ATX LGA1155
Lan driver has also been updated top the current version
Sometimes when computer A downloads something, Computer B gets high ping.
Cable type: CAT V
Cable type: CAT V
