Hello folks,
I decided to build my second rig, but I am quite unsure whether the components I have chosen will:
a) GPU Fit in the case of choice
b) Work well, especially if I am to do some games on it.
c) my AM3+ CPU will it be comaptible with the Mobo I have chosen? Although they do state that it supports the FX series, the mobo itself is AM3
Storage:
SSD Kingston 60Gb
HDD 500 Gb SATA III
MOBO:
MSI 760GM AM3
CASE:
ANTEC One Midi Tower
Memory:
G-Skill 8GB RipJaw 1333Mhz
Optic Drive:
LG GH24NS95
Power Supply Unit:
Corsair Builder Series CX 500 Watt
CPU:
AMD FX6300
GPU:
EVGA GeForce GTX 660
As you may see, I am on a limited budget, so I am trying to keep it to the minimum, any thoughts :/ ?
EDIT: Sry noticed that link was broken to the Motherboard.
Storage:
SSD Kingston 60Gb
HDD 500 Gb SATA III
MOBO:
MSI 760GM AM3
CASE:
Memory:
Optic Drive:
LG GH24NS95
Power Supply Unit:
CPU:
AMD FX6300
GPU:
