I'm a brand new builder so I apologize ahead of time for any ignorance on my part. I did my research online via the forums here, overclock.net, and other various articles. I tried to pick brands based on quality and reliability. I'd appreciate any feedback you could give me.
Budget Range: $2000 after shipping and rebates.
System Usage from Most to Least Important: 3D modeling (maya), photo manipulation (PS CS6), Gaming
Are you buying a monitor: No
Do you need to buy OS: Yes
Parts Preferences: Intel Haswell CPU
Overclocking: Yes
SLI or Crossfire: Yes
Your Monitor Resolution:1920x1200
I selected most of the the brands for quality/reliability. I don't mind shelling out a little extra for the better brand. My parts list as follows:
CPU: i5-4670K Haswell 3.4GHz
MOBO: ASUS MAXIMUS VI HERO LGA 1150 Intel Z87
GPU: EVGA 04G-P4-3768-KR GeForce GTX 760 FTW 4GB
I've read that the 4GB version has trouble with the motherboard sometimes. Is the 4GB version worth it over the 2GB? I do plan to eventually run two in SLI.
RAM: G.SKILL Ripjaws X Series 16GB (2 x 8GB) DDR3 1600
Cooler: Noctua NH-D14
SSD: SAMSUNG 840 EVO 120GB
Optical 1: LG BD-R
PSU: CORSAIR AX860 860W
I wanted to give my self extra room for overclocking plus anything I'd be running out of the USB ports. Let me know if 860w is still overkill in your opinion.
Case: Corsair 650D
I also plan to throw in an old DvD burner and second hard drive that I have. I'd very much appreciate any other advice or ideas you guys might have. Thanks in advance.
Overclocking: Yes
Optical 1: LG BD-R
Case: Corsair 650D
